garyWnight
- Jan 20, 2020
I received my new backup parking camera just now.
So exciting and can't wait to install it.
I was going to buy one of those until I read in the fine print that they fade over time. However, the one in the picture looks different than the one I was looking at.Welcome light
Is it just mounted to the bottom of the door?I hope it doesn’t fade ! But it was pretty cheap so if it does I can replace it pretty easily or the novelty might wear off too lol
It’s mounted on the door . Comes with 3m adhesive it’s held on pretty strongIs it just mounted to the bottom of the door?
Thx, Stuck with the OEM duratracs since they are like new and I like the look and ride . When it's time I may switch them out for set of Nitto Trail or Ridge Grapplers^^^. Nice, what size and brand tires did you go with ?
I may be wrong, but I think I had read that those "cracks" in the rear window trim are actually part of the design and suppose to be there. My back glass was leaking right after I got my truck so I took it to the dealer. They found a piece of white plastic that was stuck to one of the sunroof drains (in between the cab and bed). This is the same stick on plastic that is on new vehicles when they are being delivered from the factory. Whoever took the plastic off of my truck got a piece of it stuck on the sunroof drain causing the water to backup into the cab. May not be a solution to your problem but always check your drains!Installed N-FAB Podium steps, crossed the 1000 mile mark, cleaned her up before the week full of rain, and took some photos of the leaking rear window (cracks on both sides of the rear slider) View attachment 49647 View attachment 49645 View attachment 49646
The crack on the other side of the slider is definitely a crack, it’s zig zagged and jagged. Wasn’t there last week, but’s also not leaking on that side either.I may be wrong, but I think I had read that those "cracks" in the rear window trim are actually part of the design and suppose to be there. My back glass was leaking right after I got my truck so I took it to the dealer. They found a piece of white plastic that was stuck to one of the sunroof drains (in between the cab and bed). This is the same stick on plastic that is on new vehicles when they are being delivered from the factory. Whoever took the plastic off of my truck got a piece of it stuck on the sunroof drain causing the water to backup into the cab. May not be a solution to your problem but always check your drains!
Got my wheels installed today on the Rebel, next up 2 inch front level kit.
Fuel Coverts
18x9 1mm offset
Thx, haven't seen the red yet but I know the black with bronze centers looks awesome on red trucks.Man those look nice.
I’m really starting to like those wheels in red.
