Rubbing when turning 2020 Ram Bighorn 4x4
Azhalvy13
2020 Ram BigHorn 4x4 1200 miles....
Ok, so I have the ‘popping’ sound when turning right at slow speed over bumps that many have reported. So I searched this site, found lots of suggestions. Went out to investigate and found rub marks on the front suspension. Clearly it’s when turning all the way left or right (although the popping noise I am experience is only when turning right). I have not made and modifications to the suspension or wheels (yet), everything is stock.
Anyone see this? Possible cause?
You are my hero. I have been trying to figure this out and the issue is on multiple forums. I guess the issue is hard right or hard left turns. Now I am not worried as it just is light scraping which should not be an issue. I will try to not turn hard right and left anymore.
Well, took my truck in for the scraping and for the ’bumping’ noise when turning and hitting a bump. They tighten the sway bar. It has seems to help a little but definitely still hear the noise.
As for the scraping, my service advisor said 2 techs looked at it and have determined it is “normal”.....
Hi @Azhalvy13 - I regret to hear that your dealer was not able to remedy your current concerns. When you plan to head back to address your leak, please let us know so that we can get a case escalated on your behalf for support to address both of these concerns further. .
Mark
RamCares
