jdmartin
I don't think I've seen this angle covered here yet.
I have the tow package, which means I have the non-power folding tow mirrors. I've read up on swapping out the mirrors and adding the door module and doing the bcm flash to update the system so everything works.
My question is: what if you don't care about power folding, and only want the regular mirrors so that you can have the heating function work? I have found on frosty mornings that what I really miss from my Titan is the heated mirrors. Of course I want the power adjust to still work, but I couldn't care less if I had power folding.
Would a bcm flash be required if you just swapped mirrors in order to get just the heated feature? If you hit the rear defrost button ( I have the 8.4 screen with buttons below) does that activate the heated mirrors, and is there a live lead to the mIrrors that just doesn't work on the tow mirrors but would work on the regular mirrors? Are there side lights on the regular mirrors and would those work?
Finally, has anyone done this? Thanks all!
