Had a borla muffler installed and the weep holes made it sound like crap.... took it back to the shop and they welded the holes closed... MUCH better sound. I think with the added air flow and higher temps There is little concern for corrosion. If they do then I’ll just remove...each rear resonator has 4 holes, 2 on the front and 2 on the rear of each resonator. plugging them up after a muffler install really cleans up the exhaust note alot by eliminating the "air" sound you will get.
What Borla Muffler do you have? I have a ProXS sitting in my garage and debating on what I want to do with the resonators.Had a borla muffler installed and the weep holes made it sound like crap.... took it back to the shop and they welded the holes closed... MUCH better sound. I think with the added air flow and higher temps There is little concern for corrosion. If they do then I’ll just remove...
100% agree! I installed a bolt on Carven kit and those weep holes were creating an awful spitting sound....plugged them up last night and WOW does it sound better. If they crater, I'll just put straight pipes.Had a borla muffler installed and the weep holes made it sound like crap.... took it back to the shop and they welded the holes closed... MUCH better sound. I think with the added air flow and higher temps There is little concern for corrosion. If they do then I’ll just remove...
So to plug off the holes, what did you all use to do it?
I had a Magnaflow muffler installed and I didn't like the sound with the weep holes open. Put some tape over them and it cleaned it up a lot, but didn't hold up well. I took it back to the shop that installed my muffler and they welded them for me in about 5 min. I figure I'll be pulling the trigger on a cat back before I have any issues with the rear resonators anyway.I am thinking about ordering the B2 muffler and doing leaving the rear resonators but does has anyone had problems with it in cold temps? I saw a review somewhere that the holes allow moisture to escape. I am new to this so worry that if I plus the holes, I will have issues in the Winter here in Vermont. Any advise?
I had a Magnaflow muffler installed and I didn't like the sound with the weep holes open. Put some tape over them and it cleaned it up a lot, but did hold up well. I took it back to the shop that installed my muffler and they welded them for me in about 5 min. I figure I'll be pulling the trigger on a cat back before I have any issues with the rear resonators anyway.
