Have we figured out which wire to cut to kill the LED strips in the headlights?
mike_ct
first one to mention tazer dt or uconnect drl settings is a DB
Which LED strip are you referring too? Do you have the LED light from the factory or you added them later? If you have them from factory can you please try and pinout the connector's + and - as I am trying to build my on harness to go from the factory non LED harness to the factory LED lights without a DRL feature just a straight adapter.
you're the man! and good luck with your harness!
Thanks! I think I got an idea on the harness I was just wondering if the box on the Retroshop harness has any electronics in it or is just a junction box? I anyone reading this can chime in would be great.
I realize that with the factory installed LEDs you don't have the option to turn the led accents off while the ignition is on correct? That's what you were trying to get done?
You can just go back to the dealer and they can shut it off.
yep thats it. I've messed with all the settings in alfaobd and pulling fuses, I couldn't get them to shut off.
