Bestcoast
- Dec 14, 2019
Hey I’m new here. I‘ve been searching to see if you could fit a 35x12.50r20 on the stock Laramie 20’s without a wheel spacer and with a 2” level on the front. I tow frequently and often have a load in the bed so I wanted a little rake still so I went with the motofab 2” strut spacer on the front. Seeing that the stock UCA is used by ram on trucks with up to a 2” lift I chose not to replace it.
I couldn’t find a definitive answer on whether or not 35’s would fit without a wheel spacer and I was concerned that I may hit the balljoint on the upper control arm but I’m happy to report they don’t hit! It’s tight but they clear. Other than that it looks like the only rubbing will be the Mopar mud flaps
The truck is a 19 Laramie with 3.92’s and the flowmaster outlaw bolt in replacement muffler.
