Bed utility rail nuts
cj7
MD
Anyone found a bed utility rail nut that fits?
My Frontier had Utili-Trak channel that fit standard Unistrut spring nuts.
The RAM version is smaller.
Are you talking about the bed accessory rails that slide? I am trying to get a few more too if you are
They come with the Mopar bed rails so there will be a Ram part #. I recommend using them as they are hexagonal and fit the holes in the bed sides. They won't spin when you are putting the bolts in.
Probably not cheap but one of the Mopar parts discount sites or maybe Ebay are options.
They are metric, 6mm IIRC.
Pretty sure he is referring to a spring nut to fit in to the channel of the utility rail. Not the crush nuts that are used for mounting the rails.
FYI hope it helps.
