rebel without a cause
- Feb 11, 2020
The last time it happened they replaced both hubs but there were no guarantees. Ford has had this problem for many years.
Don't blame you...yikes, that would get expensive after warranty. Besides being a royal PITA. Good move.I also dumped my 2017 F-150 for a 2020 Rebel.
But I had an issue with my 2017 regarding the IWE system. The IWE needs vacuum to stay in 2wd. If you have a vacuum leak it will try to engage 4wd. If you have partial vacuum then 4wd won't fully engage. Keep in mind this is all while your selector is in the 2wd position. By default if the IWE system fully fails the truck defaults to 4wd no matter that the selector is in 2wd. The diaphragm in the check valves have been failing. Not a 100% failure just unable to completely seal for full vacuum. This partial failure is causing the IWE to partially start to engage the 4wd default.
This happened to me a total of 5 times in a 3 year span and the truck only had 20K miles on it when I turned it in. Always fixed free under warranty but still a pain the *** and after warranty ran out the truck went, bye, bye.
Yep, the IWE has been an ongoing F150 problem for years now. From the F150 forum dated 1-5-2018:Don't blame you...yikes, that would get expensive after warranty. Besides being a royal PITA. Good move.
FTR, I never had this problem with any of the four F150's I had (2009, 2013, 2015, 2017), but if I had, I would've gotten out of it, too.
I think you'll improve but not to what your 2.7 Ferd gave you. With 3.21's and 7600 miles, driving "average" (with the flow of traffic on I-40) I am at 19. Not bad for a 4x4 Ltd with 3.21 and stock rims/tires. The hemi is just thirstier, always has been. Think 5.4 as far as Ferd trucks go.I too got out of a 2017 F150. It was a 2.7 with the 6 speed (only engine available with the 6 speed in 17, the 10 speed wasn’t well refined at the time which is why I ended up with the little Ecoboost). Anyway, the truck overall was great, aside from a drivers seat that broke early in my lease, and numerous dealers with very poor customer service. The fuel mileage was really nice for a full size truck that got driven pretty hard, 19mpg in winter and 21 summer, 50/50 driving. The biggest reasons I didn’t go with Ford again was the poor dealership service department experience and it seemed like getting a new iPhone in the sense that for the most part there isn’t a ton of difference between the 17 and the 20.
The new Ram is pretty awesome as far as fit and finish, options, comfort, and overall appearance. But yesterday I took an 85 mile trip each way and was appalled by what I saw for fuel economy. I’m in central Ohio which is pretty flat and running 70-80 depending on where I was I averaged 14.5mpg! My typical daily drive is back roads and stop and go, and I have been averaging 12mpg while babying it most of the time, but I didn’t think too much of it until I saw what it did on the highway. Once I saw the highway mileage I was pretty depressed!
I am hoping that this is a combination of having winter fuel, and only 500 miles on it... I hope it improves though because it’s quite poor compared to what the window sticker said it was supposed to be and what I had found from research before buying.
Truck is 1500 Laramie crew cab, non etorque hemi, 4wd, 3.21 rear end.
