Has anyone found extended flares that will fit a Rebel?  Bough my truck with a lift and 35x13.5s.  The factor flares don’t protect the body much at all.  All of the flares I can find say they don’t fit the Rebel.  Any help?  Thanks
			btw, Mopar has the flares that should fit rebel, it's https://www.allmoparparts.com/sku/82215284ab.html
Those DO NOT FIT THE REBEL...BTDT Only non Rebel front ends
				 5thgenrams.com
					5thgenrams.com
				The shapes etc is the same, the difference is the holes, Rebels flares have holes already on the fenders, where as non Rebel are secure from the wheel wells, this thread shows how it's removed:
Fender Flare Removal
Has anyone removed the factory flares on the 2019 Rebels? In order to remove the grill, there are bolts behind the plastic trim piece between the bumper and headlight that need to be removed. It looks like to remove that trim piece would require removing the factory flare which I can’t figure...5thgenrams.com
You can see here on non Rebels those holes are not present, they are installed by drilling from the wheel wells with existing holes, and most are double sided tapes to the fenders.
Bahaha this is the truck equivalent of “send nudes plz.”Can you post pictures of ur truck
It's more than that...the fender flares are too long in front and go past the front fender onto the REBEL bumper...if you were to trim them, the trim line would cut through the first rivet hole.
THESE DO NOT FIT - PERIOD
all their fenders exclude REBEL modelsRight forgot about the front facia, I think OTG concept parts will show up in Mopar catalog later this year, including the bumper.
Edit: so I was browsing last night and saw this fella, he has a Rebel that he painted the bumpers and seem to have flares from Bushwacker.
Yes, but somehow that fella in the video got one that looks like it to work on a Rebel, hence I recommend may be ask him on how did he get it to fit, may be he found a part number that works on Rebel, or may be he trimmed it to fit.
Pictures??For those still wondering, just received confirmation from Bushwacker that the Fender Flares for the 19/20 Rebels will be available starting APRIL of this year (2020).
				 www.fiberwerx.com
					www.fiberwerx.com
