Laramie seats in a Bighorn
Grey03svt
Looking to put a donor trucks Laramie front ventilated seats in my Bighorn. Are they plug and play? I have heated seats and only driver power seat. Will I gain the function of a power passenger seat with the factory wire harness? Will my seat wire harnesses have the plug for the ventilated seat function? Main reason for this is the ventilated seats and the leather.
I've been researching the AlfaOBD stuff and looks like I can add that button feature to my 12in screen.
Any advice on this would be appreciated! Thanks in advance!
The extra plugs should be under the seats/under the carpet still. My 4th gen was that way. Youd need to turn that feature on by having the dealer program it or use Alfaobd.
I am looking to do the same, where did you find the loaner truck for the seats?
Ive found a few locally in the junkyards. But they want an arm and a leg for the seats and none were black leather (n)
OK thanks. I looked on copart to even see about going that route but seems a little expensive. I may just go with the katzkin cover.
I found a set online from a salvage dealer In Michigan. I used car-part.com to look for them. Got the full set with blown side airbags for $925.
Did you end up installing them? I'm curious about the wiring for the heated rear seats.
I did put them in. Fromt seats only though. Whiteinh harnesses plug right in. Rear seat were from a quad cab so I could not put them in my crew cab. They did not have heated seats either. I do not think the wiring is there in the Bighorn for rear heated heats. But I could be wrong
