Headlight Assembly
DonsRam19
South Carolina
Atlantic Blue
They look awesome someone needs to try these out so I can see how they look!
There is a photo in the link showing the install on what looks to be a Big Horn. the kit Comes with Halogen bulbs - so you may still want to upgrade the low and high beams. The Housing caps look like they may need to be cut/modified for upgraded bulbs.
moosem
Rhode Island
These are only for Tradesmans and Big Horns with halogen lights.
It states on the website:
Only fits Ram with halogen type headlights, does not fit Ram with stock LED headlights
They are pretty cool looking, but they’re more expensive than OEM full LED housings. But it will be a more custom look.
Stony0604
Yes, i have a bighorn with halogen currently. I couldn't find any OEM LED's for under 1K a pair. These ended up costing around $566 for the pair after some coupon codes i found online, plus i won't need to buy the adapter to make the change from halogen to LED as well.
green68mustang_2002
Can almost guarantee that the light output is going to suck. They look like a rebranded spyder, or something similar, housing and those are horrible!
moosem
Rhode Island
Yeah, I thought about it afterwards. These are definitely cheaper. I was thinking that the price was per side, not for the pair. I think they will look good. Look forward to seeing pics.
RAM Patriot
Clayton GA
Well, I pulled the trigger and bought them. I'm post a pic after i receive and install them.
Following this thread...
I'm interested in these if they are better than the stock reflector headlights on the Bighorn and the DRL LED are bright enough.
Firebird
Those really look good, please keep us posted
Mrwilcox281
Queen Creek, AZ
The cut off line from the photos looks good. Our stock housing is not bad for a reflector, I just added a set of LED bulbs from headlight revolution and its a fantastic upgrade. I figure these should be pretty good with a solid bulb.
RAMBS
I like the sidelight illumination on our stock headlights. Do the custom ones include that?
RAM Patriot
Clayton GA
