Default to navigation view
mitchapolooza
I own 2019 dodge ram 1500 just wondering if it is possible on startup to have the screen always default to display the map?
I can't find a setting for this and I have to do this manually everytime I start my truck.
I haven't found any way to do that... bugs the crap out of me. IMHO the system should just stay on the same screen between restarts.
Not sure but I think if you establish a profile, when you start the truck everything returns to what you had when you turned it off. Depending on your Model. IE, Laramie longhorn, Limited with the FOB set to 1 0r two, and a profile on the Radio.
I believe the Profile (you can have a couple on Infotainment system) will incorporate memory for pretty much your preferences on restart of truck. Example, Seat set to heat, cool, radio station on last channel, etc.
Do you mean full-screen nav (which you can save with seat memory) or half-screen nav showing the map instead of favorites (which isn’t possible)?
