Sorry, Alpine. From what I've read about the HK system, and that HK make Inifinity, I am thinking they are already putting something similar to the Inifinty's in the dash and doors.
Not similar unfortunately. Infinity aftermarket speakers are far better than HK stock speakers. That and the HK amplifier still boosts the subwoofer way beyond flat and makes bass sound like ****. Had to use my own amp in for the stock subwoofer.
Installed viofo a129 duo dashcam, really like the quality, With parkingmode on truck is always safe.
Which is currently my problem. I have the bass at -7 and it's still overbearing at times. The highs are descent so I don't think i need to change the dash ones. How did you run a second amp? Wish there was a way to tune everything as it is.
Absolute love your truck.
I'm searching for exactly the same amber lights in the grill to install, can you give me information about those?
Are they switched on, or set up when headlights are one ?
Thanks !
Bought the light of eBay for the Toyota Tacoma. They fit perfectly. Connected them to the trailer light in the fuse box.
Really like this style with LEDs, do you have some information where you bought these or product number ?
I'm searching for weeks but cant find correct one unfortunately.
These are the ones that I purchased and installed ---->
I've hit 2k miles so far and love it.
So far, linex in the bed, weathertech floor mats and rear seat cover to protect it from the dog and grandkids. Yesterday got the Tyger running boards installed.
Hopefully next week the leveling kit up front and some real tires.
Got the tonneau cover on, went with the truxedo lo pro with ram box, looks good, easy to clean, stays tight. keeps out 98% of water going through drive through car washes after i added weather stripping. I had cardboard boxes back there and they didn't get wet, only a bit of water makes it through the corners
Added mud flaps. I go on job sites and didn't want my power steps filling up with mud
links:
I've been holding off on my install of the same dual channel cam because I couldn't find a good reference for detailed instructions to 1) pull the side panel off the dash to get to the fuse box or 2) which fuses to tap. Also, how did you end up mounting the rear cam?
All information needed for correct install on this page:
Also, you need 2 fuses, F33 for battery power all time, and fuse F66 ignition on ( switched )
Third cable is your ground, next to fuse box there are some M6 screws for mounting.
The fuse box is direct under steeringcolum, mounted with 2 bolts. The small side panel is only for cable mounting, you cant access the fuse box normally via side panel.
Right now rear cam mounted with 3m tape, but will make a bracket a.s.a.p.
Hope this helps, you can message me always.
Pedal Commander. VERY impressed
I replaced the 3 dash with Reference 2 ways as you did, the sound quality for mids/his much improved. Then replaced the rear doors with reference 6x9 3 ways. Sound quality with mids/his got even better. Then after another month decided to change the front doors with reference 6x9 2 way components, using just the woofers. Even more improvement with tighter bass. Could have just gotten 2 ways for fronts as the tweeters would have just been unused, but the price diff was about 30 bucks so just got the components so the speakers are fully appropriate for the applications. I think the system now sounds awesome. On par, or better, than other high end factory systems I have heard. Total cost was about 400$ with harnesses and shipping. Got all speakers from Amazon and harnesses from Crutchfield.
Which infinity 2 ways did you get?
