Drivetrain clunk
Binny01
Cruising on the highway, when I get a muffled clunk from the drivetrain, along with a brief hesitation in power. Then truck continues on fine. Only occurs occasionally. Worried that this may get worse AFTER warranty is up. Any ideas? Any related threads here I can look at?
2019 Bighorn; 5.7; 4x4 Quad cab
There's a TCM TSB in the warranty section of the forum. addresses rough shifts, hesitation on shifts, and rear end clunk due to less than optimal shift points. firmware upgrade to fix if that is the case and estimated at less than an hour of actual tech time. so.... 2-3 weeks in the shop.
Hi Binny01,
If you end up addressing this with your dealer, please be sure to let us know via private message. We are more than happy to escalate a case on your behalf to get you connected with a specialist for an extra layer of support through that process.
Mark
RamCares
The firmware update for the drivetrain clunk is only temporary. I thought mine was fixed; but it returned after a few thousand miles.
