Added factory subwoofer to base system w/ANC
lapedr
If anyone is interested, I just finished adding a factory sub to my 2019 Big Horn w/base 6-spkr system and ANC, and it sounds amazing. The sub is pn 68277288AB (premium audio). Total load on the channel is 2.67-Ohms which I got by splicing the (3) voice coils into the left rear door speaker output at the ANC (1x 2-Ohm speaker in the left rear door, (3) 2-Ohm voice coils in sub).
Any pictures of the install? Did you also add an amp or use the one with the subwoofer ?
I was going to install the factory Mopar amp that went with the sub but I couldn't get the amp to work (no sound) so I decided to just splice into existing ANC module speaker output wires. The sub was factory so it bolted right into place on the rear cabin wall behind the rear seat. I did have to cut out an 8" circle on the rear cabin trim panel using a compass to draw the 8" circle, and a razor knife to cut the hole. I used the connector in the Mopar Connection Repair Kit pn# 68030094AA (http://connectors.dcctools.com/home.htm) to connect the sub speaker wires to the sub so I didn't have to cut any wires on the sub itself. I then ran the sub speaker wires along the bottom cabin wall, up the rocker panel along side the factory wiring harness to the ANC module black connector under the drivers seat. The wires I spliced into at the ANC module were pin #5 ( GY/GN LR +), and pin #13 ( GY/DG LR -). I did not disconnect or bypass anything so all the accessories function as they should (noise cancellation, mics, speed adj volume, carplay etc.). I really wasn't thinking it would sound that good but I was totally shocked when I fired up the system and felt the "thump". This actually sounds better than the 9-spkr Alpine system I had in my 2014 Sport.
That connectors link is a gold mine on information.
Might be attempting this soon!
Are you saying the only connection you made was the speaker wire splice? No other connections for power/etc?
Do you have any pictures of it mounted?? Think I may attempt to install the one I got out of a totaled truck today
Will it be enough watts per channel to power both the door speaker and the sub? I assume the power splits in half between the speaker and the sub, which will make the sub and speaker sound at not their full potential. Thanks.
Do you still have the factory amp for the sub? If so what would you sell it for?
I tried this. The sub is for sure not powered enough. It breaks up and distorts.
do you have the same size 8” subs ? same output ?
but i wanna change my factory sub or maybe just add another 8 inch sub i have alphines systems
Any updates or photos of this? Did you ever add a sub?
Does anyone have a wiring diagram of part#68030094aa and to the anc module. As I am trying to do the same thing in my 2021 ram 1500 big horn 6 speaker system.
Hopefully this helps...
SPEAKER-SUBWOOFER​
68030094AA​
No terminal repair kits have been identified.
End View​
Isometric View​
PinCircuitGaugeColorFunction
1X3000.75GY/BNAMPLIFIED SUBWOOFER 1 (+)
2X3900.75DG/BNAMPLIFIED SUBWOOFER 1 (-)
3X3010.75GY/WHAMPLIFIED SUBWOOFER 2 (+)
4X3910.75DG/WHAMPLIFIED SUBWOOFER 2 (-)
5X3050.75GY/OGAMPLIFIED SUBWOOFER 3 (+)
6X3950.75DG/OGAMPLIFIED SUBWOOFER 3 (-)
MODULE-ACTIVE NOISE CANCELLATION C2​
Harness Family:
IP
Cavities:
22
Color:
Gender:
FEMALE
Part Description:
1438759-1
Connector No:
D2594B
Option:
Standard
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1Z912BK/1.5GROUND
2D245BN/GY0.35CAN IHS (+)
3N0NA/0NO CONNECT
4X51DG/DB0.35LEFT REAR SPEAKER (+)
5X52GY/DB0.35RIGHT REAR SPEAKER (+)
6X53DG/0.35RADIO LEFT FRONT AUDIO (+)
7X54GY/0.35RADIO RIGHT FRONT AUDIO (+)
8X460BN/OG0.35ANC MICROPHONE 1 (+)
9X462BN/WH0.35ANC MICROPHONE 2 (+)
10X474OG/DB0.35ANC MICROPHONE 3 (+)
11X476OG/GN0.35ANC MICROPHONE 4 (+)
12A931RD/1.5FUSED B(+)
13D244WH/0.35CAN IHS (-)
14N0NA/0NO CONNECT
15X57DG/OG0.35LEFT REAR SPEAKER (-)
16X58GY/OG0.35RIGHT REAR SPEAKER (-)
17X55DG/BN0.35RADIO LEFT FRONT AUDIO (-)
18X56GY/BN0.35RADIO RIGHT FRONT AUDIO (-)
19X461BN/VT0.35ANC MICROPHONE 1 (-)
20X463BN/GY0.35ANC MICROPHONE 2 (-)
21X475OG/DG0.35ANC MICROPHONE 3 (-)
22X477OG/BU0.35ANC MICROPHONE 4 (-)
MODULE-ACTIVE NOISE CANCELLATION C3​
Harness Family:
IP
Cavities:
16
Color:
Gender:
FEMALE
Part Description:
175966-2
Connector No:
D2594C
Option:
Standard
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1X478BN/GN0.35ANC BUFFERED CRANK POSITION (+)
2N0NA/0NO CONNECT
3X201GY/VT0.50LEFT FRONT SPEAKER (+)
4X202DG/VT0.50RIGHT FRONT SPEAKER (+)
5X205GY/GN0.50LEFT REAR SPEAKER (+)
6X206DG/GN0.50RIGHT REAR SPEAKER (+)
7N0NA/0NO CONNECT
8N0NA/0NO CONNECT
9X479BN/DG0.35ANC BUFFERED CRANK POSITION (-)
10N0NA/0NO CONNECT
11X291GY/YE0.50LEFT FRONT SPEAKER (-)
12X292DG/YE0.50RIGHT FRONT SPEAKER (-)
13X295GY/DG0.50LEFT REAR SPEAKER (-)
14X296DG/GY0.50RIGHT REAR SPEAKER (-)
15N0NA/0NO CONNECT
16N0NA/0NO CONNECT
AMPLIFIER-RADIO C1​
Harness Family:
IP
Cavities:
22
Color:
Gender:
FEMALE
Part Description:
1438761-6
Connector No:
D3804A
Option:
Standard
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1Z912BK/3.0GROUND
2N0NA/0NO CONNECT
3N0NA/0NO CONNECT
4X205GY/GN0.75LEFT REAR SPEAKER (+)
5X206DG/GN0.75RIGHT REAR SPEAKER (+)
6X300GY/BN0.75AMPLIFIED SUBWOOFER 1 (+)
7X200GY/BN0.75AMPLIFIED CENTER I/P SPEAKER (+)
8X303DG/BG0.75AMPLIFIED LEFT REAR SPEAKER (+)
9X301GY/WH0.75AMPLIFIED SUBWOOFER 2 (+)
10X304DG/BN0.75AMPLIFIED RIGHT REAR SPEAKER (+)
11N0NA/0NO CONNECT
12A931RD/3.0FUSED B(+)
13N0NA/0NO CONNECT
14N0NA/0NO CONNECT
15X295GY/DG0.75LEFT REAR SPEAKER (-)
16X296DG/GY0.75RIGHT REAR SPEAKER (-)
17X390DG/BN0.75AMPLIFIED SUBWOOFER 1 (-)
18X290GY/OG0.75AMPLIFIED CENTER I/P SPEAKER (-)
19X393DG/GY0.75AMPLIFIED LEFT REAR SPEAKER (-)
20X391DG/WH0.75AMPLIFIED SUBWOOFER 2 (-)
21X394YE/GY0.75AMPLIFIED RIGHT REAR SPEAKER (-)
22N0NA/0NO CONNECT
Has anyone else got a good sound with the sub installed? Post #2 says about no good sound. Thinking about this mod too.
I'd be interested in adding the "factory sub" but then trying to find a replacement woofer for the factory enclosure. Has anyone tried it this way?
My Bighorn 'did' come with the base 6 spkr w/anc non Nav... the sound is Ok for what it is.... But at present I am modding my system to the Factory Alpine 9... I have it half complete and it doesn't sound too bad... I wanted to keep it simple and clean... don't need my ears to bleed---been there :) I am using all OEM parts ( mostly )
Once complete, if there is enough interest, I will post a how-to with part numbers...
-=FM45=-
