My truck came with a dampner.
My tailgate is dampened as well.I was changing out the reverse bulbs and noticed this on the passenger side. It looks like it's a mount for a strut to dampen the tailgate.
Here's a place you can buy it at a discount with free shipping. I've used them several times without issue.Here's the link to the Mopar Store for a tailgate dampner.
Factory OEM Ram Parts & Accessories | Mopar eStore
Get The Best Prices On Ram OEM Parts And Accessories Delivered To Your Home From Our National Ram Auto Parts Store!store.mopar.com
I've retrofitted the damper to my truck. Easy mod and does its job. Highly recommended.
Dee see sells a damper for the 2019 ram on amazon. Easy install.I was changing out the reverse bulbs and noticed this on the passenger side. It looks like it's a mount for a strut to dampen the tailgate.
Thanks. I did not know they are different. I have the 1500.I ordered the 43302 but it was too long. Couldn't close the tailgate. Perhaps it fits the 1500 though.
Just wanted others to know that it will not fit the 2500
There shouldn't be a difference. When you installed it did you close the tailgate and then install it and push down on the shock? It should fit. I had to do it on mine when installing it.
On the 1500 it's under the driver's tail light, right?
On the 2500 it's on the passenger side. The instructions that came with the Dee Zee damper had a huge note that said it fits the 1500 only. I tried it anyway but it was too long.
the upper trim levels come with them as a standard item. My 1500 didnt come with one but I picked it up on amazon for $49.00 and free shipping. Just be careful pulling the drivers side rear light out. If you dont gently withdraw the plastic pegs holding the light youll bugger them up and have to replace them at 1.29 a piece. Otherwise 10 min insulation.
.On the 1500 it's under the driver's tail light, right?
I went to my dealer, faster to get the plastic pegs, and not much different in price.Where did you find those plastic pegs?
