Twoamen
Dealer called yesterday. Truck repaired. Lengthy statement on his tech. tracing a low voltage drop in the ABS system. A white/green wire traced back from the Canbus to a pin that was loose connection. Tech pushed pin, seated and voltage returned to normal. Batter checked out good.   Note: somewhere  I read a similar problem with an ABS connection causing dead battery. Started when I left dealer, and Started again when I left the  vehicle Rental to home. Watched voltage all way home at 14.5.
So plan B is on hold.
