I did my first oil change at 1,900 miles today.
I've been changing my own oil in my vehicles for 30+ years, and I must say, this RAM is a b*tch!
I used to just lie on my back under my Sierra and get it done. I figured with this RAM on 20's, I would have even more clearance, but that was not the case. I took out my trusty metal car ramps but no go, as they say max tire width is 9". So, out came the jack , wheel chocks and jack stands.
There is not enough clearance behind the sway bar to get a socket on the drain plug. A combo wrench worked, but it would have been nice to have the leverage of the ratchet for that tight bolt.
OIL WENT EVERYWHERE!
Oil splashed off the sway bar and hit my catch pan at all angles causing more splashing. I had lots of cardboard down but oil still found its way to my garage floor. I attempted to make some kind of barrier to direct the oil before I took out the drain plug, but nothing seemed like it would work. If the oil came out slowly it maybe would miss the sway bar, but it comes out fast!
The oil filter wasn't too bad, but I did have to mangle it with a filter wrench before she loosened up. I did the zip lock bag trick and managed to keep most of the oil from the filter in the bag.
Lot's of cleanup afterwards, but it's done.
