Getting into the bed...
Heavycivil
Central NC
Well, I've had my truck for all of 3 days and boy oh boy is it difficult to climb into the bed...my prior 2500HD had a place to insert your foot on each side of the bumper (not that you all didn't know this) but currently, mine has no insert nor deployable bed steps...I guess the mods will begin soon or than I expected. I haven't searched the forum yet but any thoughts/suggestions.
I’m pretty sure with his being a 3500 and what appears to still be the 4th gen style that that may not work.
Originally, I was considering the Mopar Bed Step but felt it was WAY too overpriced. Heck, for a couple hundred dollars more, you can buy an aftermarket rear bumper with the steps built in. I had one on my 2015 Ram Sport and worked/looked great.
Anyways, I was Christmas shopping for myself online and found one of these:
It was a no-brainer for $35.88 on Amazon. Probably one of the best "cheap mods" I've done on my 2019 Rebel.
Works well, is easy to install and is very sturdy. I have two undercover swing cases and a Peragon hard bed cover. The tailgate ladder clears both and the support cable for the tailgate.
It's a great alternative to the overpriced Mopar bed step.
Hope this helps!
View attachment 42373View attachment 42374View attachment 42375
Hope this helps!
I've thought of getting one of those before but I need my tailgate clean for sliding tools, lumber and appliances in and out of the bed.
OP: I have two approaches to this:
1. I bought an $18 fold up metal platform from Harbor Freight. It fits in a storage bin when I don't need it and is either 12 or 18 inches tall, just enough to step up.
2. When I'm doing something fast and/or it's not handy, I face away from the tailgate and hop my *** up on the tailgate. Then I can just climb in.
Step on the bumper and over the tailgate. Then release the tailgate while standing in the bed.
I had the same concerns but I just move the Ladder out of the way before sliding anything on the tailgate that fits in bed. It literally takes about 4 seconds to engage/disengage.
If you have to use the tailgate for hauling (ie item doesn’t fit in bed with tailgate closed) then yes, the ladder will be rendered unusable if underneath the item you’re hauling. You can stack/slide things on it though...it’s pretty durable.
There’s also a step that fits over either of the rear tires for easy access to the bed ($22 on Jegs website):
Combine this with the bed ladder, you’re still under $70 for both.
I installed the Mopar bed step a month ago and I can’t believe I lived without it. Great mod and very easy to install.
This is probably the ONLY feature that I actually miss from my 2014 Silverado: the bumper side steps.
Has anyone considered adding anything to provide some more traction on the rear bumper "cut out" in front of (or is it behind?) the license plate? I was working in the bed after a rain shower and was concerned I'd slip off of it.
The higher sections of the bumper have some tread on them, but the lower section, where it's most logical to place your foot, has none. (At least on mine.) I thought about putting some adhesive-backed stair tread on there, but I'm worried how it will look in a few years. I'd love it if Mopar made a cover piece for that section with the same tread grip as the rest of the bumper.
Look for some skateboard grip tape. Should hold up really well. Just clean the plastic with some diluted rubbing alcohol before applying.
Agree, my previous 2 Silverado's had the bumper step. Simple, elegant, functional solution.
I always step on the rear tire and come up over the side; that is the way I have always done it with my trucks.
That's what I do/did with my trucks without a cap. Once you put on a cap, that's out.
Someone needs to come up with a pull-out ramp that goes through the tail gate. That would be infinitely more useful than split tailgates, little steps or anything else. It wouldn't be terribly hard to engineer, either. The ramp could stow under the bed and the tailgate could have a flip-down flapper at the top and an opening at the bottom, and then just something to grab/push the ramp through the tailgate. THAT would be an option that I bet a whole lot of people would spring for.
