Engage auto parking brake
cbadge
Omaha, NE
2019 Ram 1500 bighorn
I've been manually engaging the auto parking brake by using the button each time I park.
When I reverse it's automatically releasing as long as my seatbelt is on.
What do I need to do in order to get it to automatically engage when I put the vehicle in Park?
Thanks for the help!
Option in you setting brake system on u connect. I won't set auto parking brake since only used on downhill parking situations. My experience with auto parking brake not too good with previous vehicles. After certain cycles it start acting up so only use when necessary
You can go into the settings if you have an 8.4 alpine radio system and set it to come on and off automatically!
I use this feature too. No issues so far, but I only have 3800 miles, so I'm not a good example of a long use case. It took me a bit to realize that you have to have your seat belt fastened for it to auto-release when engaging the gear. One benefit I like is it prevents the truck from rolling forward (or backward) a few inches when you release the foot brake after putting the truck in park. This helps if I am in a tight parking space and have pulled pretty close nose to nose to another vehicle.
So is there a particular sequence one needs to do to get it to disengage? Sometimes it does. Sometimes it doesn't. Thanks.
I use the auto parking brake all the time with no problems. If I jump in on the farm and don't want the seat belt on, I just hit the release with my foot on the brake, and drive off.
The trick is to click on your seatbelt. If you put it drive without fastening belt, brake will not release automatically until you do.
As others have stated, it's all tied to your seatbelt being fastened. Since this post, I identified that once you fasten your seatbelt after you already selected a drive gear, it will release the brake when you press the gas pedal. Before, if I had already selected reverse and the parking brake was engaged, I would fasten my seatbelt and switch it to park and then back to reverse and the parking brake would release. The main difference if you put your seatbelt on before engaging the gear is that it will immediately turn off the parking brake when you select a gear. If you fasten after you selected the gear, I believe the parking brake light stays on until you give it gas. There is also a slight hesitation when you hit the gas for it to turn off the parking brake.
