MBORO19RAM
- Jun 30, 2019
as I understand it those vents are baffles for equalizing the pressure felt from opening and closing the doors. as it appears in the pic the baffles aren't blocked off but are certainly covered with batting and dynamat.You understand those vents have a purpose.
OP, This might have been the source and solution to your noise:
Road noise- interior
I ran out of time trying to install mine yesterday and saw what you are talking about. I have the weld indentions but also have the holes. My issue was that the holes don't line up with the seal. The outer two are fine but the third one in is off by about 1/2". On top of that, the seal seems...5thgenrams.com
Awesome job!
What kind of sound deadening is that?
how many sheets did it take to do the area behind the seats? also did not see a sub on the rear of the cab, what sound system do you have in your truck?
If you watch the Noico video it appears you didn't install it properly. They want it all rolled down so the dimples go flat. Did you decide to not do that or was it in error?4 sheets. Factory 6 speaker sound system. Did this to reduce noise.
How big are those vents? I will be installing Noico next week when I install my subs and am looking to do the same thing with the vents.Weekend project with my Son. I had been chasing passenger rear window sound like it was open. This mod has helped tremendously. Next will be all doors will get same treatment when I replace 6x9 speakers. Highly recommend for a quieter cab.
Wasn't meaning to offend. Honest question. I want to do the same thing to mine and trying to get all the details. ThanksI used a roller. If it doesn't look installed right I will take your word for it. It worked is all I know...
Thanks so much for sharing your solution as I will be doing it also. Question: Do the rear seats come out pretty easy? I haven't seen anything on the forum or anywhere else that mentions the seats folding down? Any special tools needed?Amazon.com: Noico Black 80 Mil 36 Sq Ft Car Sound Deadening, butyl automotive deadener restoration mat and Noise dampening insulation: Automotive
Buy Noico Black 80 Mil 36 Sq Ft Car Sound Deadening, butyl automotive deadener restoration mat and Noise dampening insulation: Insulation - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I was looking at mine and there looks to be a torx bolt but I'm not sure what size. Maybe someone can chime in.Thanks so much for sharing your solution as I will be doing it also. Question: Do the rear seats come out pretty easy? I haven't seen anything on the forum or anywhere else that mentions the seats folding down? Any special tools needed?
