Storage tray on top of dash
Bobkid
Granbury, TX
Anyone seen any good uses/additions for the storage tray on the top of the dash above the radio? Useful real estate, especially with 12 vdc power already supplied.
Not sure what I'd like to see there, maybe a plug&play dash cam, or maybe a small form factor CB radio. All I'm seeing right now is a proclip cell mount, but about the last thing I need is another cell mount option.
Ideas?
knightro84
Easley, SC
I mounted my Scangauge there. Drilled a small hole to run the OBD cable behind the dash and up to that spot. It's powered via OBD so the 12V outlet is still available for use too.
gHiDoRa
Elvis Presley
if you didn't mentions it, i would total forgot about that space, now i need to find something so i can put there. :unsure::unsure:
RAM Patriot
Clayton GA
Dashboard Platform Beanbag & Suction Cup Mount for Radar Detector
This heavy weighted Beanbag friction mount has been perfect for the basin on the front dash and I was able to tuck all of the wires underneath.
33663
It has not moved since I placed it there and I live off a curvy road.
Neurobit
RAM Sorcerer
Texas
I’m in Texas also. Does it seem like the cameras read the toll tag without any problems?
Yep. No issues. In Houston, you must also have the plate number on the account, so if it doesn’t read, they have that as backup.
Bobkid
Granbury, TX
The only time I've run into problems with that is the scanners at DFW airport. For some reason they are very picky and if you're using the Tolltag for airport parking, they might not see the tag on your way out and an attendant has to assist.
Cravenfan
Maine
I had my EZ pass toll reader in there for a while, then moved it to the dash...need to see if my Garmin Rhino will sit in there...pair of extra glasses, maybe a spare Devil Dog, or Yodel is the urge catches you while driving?
Richard320
I'm waiting for someone with the skills to make an auxiliary switch bank that fits there. Pop the socket out and you not only have a 12V power source handy, but also an easy way to run a bunch of wires through the dash.
And now I got myself curious if that 12V outlet is illuminated.
Tex_Ram
Houston, TX
I think it was AEV I spoke to a few months ago and they said they were working on this for the 5th gens.. They have them for the 4th gens
MattF
In a "I need a quick google maps nav situation" I place my iPhone horizontally in the slot (which seems designed for a phone). Works great
Matt
varnerme
Yea perfect spot for an EZ Pass
I've just had mine a couple of weeks and was wondering where to put my EZ Pass since the rear view mirror area is largely taken by whatever is behind that plastic housing. Do toll booths pick up your EZ pass sitting on the dash there? Just curious. I haven't tried yet.
Cravenfan
Maine
Yup, no problem, EZ Pass picked up no problem. I then mounted mine to the right of the camera housing above the rear view mirror area. I don't see the EZ Pass at all.
john94si
Iphone max RAM mount holder.. I actually slide the phone all the way down so it doesn't block the view like it does in the pic IMG_2793.JPG
Wakesnowb
Iphone max RAM mount holder.. I actually slide the phone all the way down so it doesn't block the view like it does in the pic View attachment 41463
These trays have a little slot in the back of them. Perfect for holding most phones in them sideways. Do you think that would be a better way to hold your phone in that general vicinity? I didn't realize that slot was there until the other day.
BoeingBigHorn
Ideas?
I put a small flat cordless charger for my LG phone. Verizon sells it and it fits there just right. But it will not activate the AutoAndroid in this plug.
