Disconnect Battery Loose info: Possible Fix
KRField
Tri-Cities, TN
So installed the trailer brake control today, and had something sliding around behind the rubber cell phone holder backing. So I disconnected the batter but before taking the negative cable off I disconnected the BATTER SENSOR first then removed the ground cable.
Well 2 hours later after having to remove half the dash to get the CD/USB/Cell phone holder out, since the rubber piece is welded in place (the could have just used rubber nipples to pop that piece off). I found a dime had some how gotten in there. I buttoned everything up. When hooking the battery up I attached the ground cable and then reconnected the battery sensor. Fired it up and everything was intact and no warning lights or error messages.
Now about 8 months ago when adding bed lights I just unhooked the ground cable and not the sensor. It was unhooked for same time frame. When hooked everything up the truck went nuts.
Maybe the sensor is the cause of the truck wigging out when the battery is disconnected. This the second time I did this procedure. The first was a couple days ago replacing a BCM harness retainer housing I broke doing the bed lights, and had same results as today.
A little help please. What is the BATTERY SENSOR, what is it’s purpose, where is it located? Thanks
The Battery Sensor is locate on the ground terminal post of the battery. I don’t know exactly what it does, I haven’t looked into it. I’m positive it feeds into the bcm for some reason.
After some research it is a battery temperature sensor. It is responsible for regulating the charging of the battery as needed.
Likely what he said, monitors state of charge or voltages. Ford has had a battery management system since 2011. Caused a lot of dead batteries I’ll tell you... their forums were full of threads about it for several years.
Another “better idea”, not.
