MilehighRam
 - Oct 10, 2019
I tried mine in a snow storm we had last month (Denver area).  They were ok at best.  ill use them through this winter, then get rid of em.
			wow, they should let the TPS know that as they go off below 38 or 3936 psi is recommended tire pressure for 22's on the door sticker.
Yeah, I turned the feature off after I found out it wasn't very accurate.wow, they should let the TPS know that as they go off below 38 or 39
Every TPMS system I've had has the ability to be calibrated to whatever pressure you want. Most through a button in the cabin somewhere...others via a dealer tool. Ram doesn't allow this?Yeah, I turned the feature off after I found out it wasn't very accurate.
I believe Twister is talking about the horn going off on the tire fill assist after you've hit 36psi.I’m running at 36 on all 4 and no tps lights
