iamtheav8r
Anyone with the 22" wheels and tires care to comment on winter performance? I'm in upstate NY and live at about 1400' elevation. I haven't had to put snows on other trucks, but also haven't had 22s before.
How many miles wore them out?Mine were fairly good the first year, when they were new. This year they suck. They’ve worn to about the bars now and aren’t worth a damn in the snow.
I’m at 14,800 right now. They wore pretty heavily in the centers. Others have shared similar issues.How many miles wore them out?
That's terrible wear! What brand and model tires do these come with?I’m at 14,800 right now. They wore pretty heavily in the centers. Others have shared similar issues.
Goodyear Eagle Touring 285/45/r22 XLThat's terrible wear! What brand and model tires do these come with?
Thanks. I ended up putting the OEM tires back on my current "truck" because the 3 other sets I tried weren't nearly as quiet. Helps that I have a friend who owns a high volume tire store.The stock tires in all new cars nowadays are intended to provide a softer ride, both in terms of test drives and first year of ownership. They also, for this reason, wear quicker. You get 20k miles out of stock tires and you’ve done well. I’m taking the stock Goodyear’s off my new 2020 immediately and will probably sell them cheap and I’m replacing them with new Continental AT tires. Mopar has a buy 3, get 4th tire for $1 sale through 11/30.
When you look at your new truck, look at the tire pattern and you should be able to realize fairly quickly that the stock tires will be ok in snow, but not great. Use your auto-4x4 and you should be fine. The 18”, 20” and 22”s should all perform about the same, based on tread pattern.
Is this due to over inflation or a defect in the tires? Thanks!
not on the 22's right? I have 45 psi in mine, tires state 50 psi max. I will probably go with Coopers next time as I am not a low profile tire fanNot over inflation. IMO. As my Service advisor at my dealer said they air all of them up to 40 psi, which I pointed out was 4 psi over the door sticker. To the response of, “doesn’t matter they are junk anyway”. I personally think it is due to the tons of roundabouts/traffic circles I take everyday. My right front seems to wear quicker than others. I’ve rotated every oil change as well. So-being junk is my opinion. They have no mileage warranty that I’m aware of. My psi is always right around 36-38.
On another note. My wife had a car that had similar tires from the same brand and hers were flat bald like I had never seen at 22k. I replaced hers with a pricey Michelin and they lasted another 35K before we sold it. They still had 60- 70% of the tread left to my surprise.
I put mine down to 36 psi as soon as I got home. It is the recommended pressure and should also mean a better ride. Higher psi might give better gas mileage but that is about all.
And I have never seen a tire manufacturer not give some kind of wear warranty...it is usually pro rated after so many miles.
