+19 offset stock
Personally, I am looking at going with +1 or possibly even 20x10 -12 offset on my aftermarket set
Thanks - think so tooThat's a good looking wheel...
They look great! Thanks for sharing! I use the tiresize.com offset calculation tool for the most when wanting to change and find that very helpful. The wheels I am looking at are these:
Vorsteiner started making truck wheels not long ago under the brand name Venomrex. This is the model 601 20x9 et12 and it is for a Raptor , but they offered to drill and machine the Ram 2019 boltpattern for me. It comes in black, gold and a graphite + some special colors, like this brushed tinted. You’ll find it at Venomrex.com They’re also coming out with previous gen and 2019 wheels in November/December - the 602 model. I just placed an order for the same as in the picture, drilled for 2019 Ram.Who makes that?
I need it.
Good looking wheel. Mine are +10 so it will sit about the same. It doesnt stick out it's about even with the edge of the fender.Thanks - think so tooand why I so badly wanted them to fit. Turns out though that it only sits 7mm further out and I guess that is no problem and still keeping them inside - more up to the tire I guess?
Yours sit great too. Do you know app how much you had from the original wheel out to the edge of the fender? Also, I see your tire makes out to be a 34,1? Is there more room or are you on the edge of needing a lift?Good looking wheel. Mine are +10 so it will sit about the same. It doesnt stick out it's about even with the edge of the fender.
34s may be the biggest you could fit without a level. Maybe 34.5. I leveled it two days later so I never measured. Woth the leveling kit I've got room for 35s, although I would have to watch the width.Yours sit great too. Do you know app how much you had from the original wheel out to the edge of the fender? Also, I see your tire makes out to be a 34,1? Is there more room or are you on the edge of needing a lift?
Great, thanks! Yes I can see the width needs to be kept down around 11" or your 275. I'll play with it a bit when I get both wheels and truck and see what looks nice and works best. I've asked them to shave off 3mm so I'll get 15 offset.34s may be the biggest you could fit without a level. Maybe 34.5. I leveled it two days later so I never measured. Woth the leveling kit I've got room for 35s, although I would have to watch the width.
I placed an order for the Venomrex 601 wheels and the service offered deserves a mention. Originally this wheel has a Ford bolt circle, but they’re drilling and machining a Ram bolt circle as well as shaving off 3 mm on the backside to get me an offset closer to original. This means I will be at +15 instead of +19 original and which then means a close to nothing difference. I am impressed to find a manufacturer willing to do this - and it was them offering, not me asking, since I didn’t even think it would be possible. Thanks!They look great! Thanks for sharing! I use the tiresize.com offset calculation tool for the most when wanting to change and find that very helpful. The wheels I am looking at are these:
They sit flush...I'll take a pic when the sun is back out.Thanks, Blazn. Great picture! Those wheel wells look fairly well filled up. Would you happen to have one that shows how far your tires stick out? Which ceramic tint are you using? And does the windshield and roof do a good job blocking heat?
