Charon
- Nov 7, 2019
I installed my locking in-floor storage today for my CCW
Pros
- Strong lid
- Bolted into metal
- Doesn't use console space
- Concealed
Cons
- Outer liner is plastic, and exposed to the undercarriage.
When choosing between this and a center console each has their benefits. I believe the most important is that this is more concealed. Thieves always rifle through center consoles and a safe inside is a huge target. I doubt floor bins will be on their list. Screws into the plastic of a center console aren't secure at all. I think it's most likely if a thief went for this it would be targeted ie: They know / saw you store your pistol there.
Installation is easy, it took maybe 10 minutes with a battery powered impact.
Ram lid removal
4x T-30 bolts
2x T-40
2x 10mm bolts
Installation
2x H4 Hex/ allen bolts for the bin
4x H4 Hex / Allen for the lid
I used loctite (so did RAM for their bolts)
One thing to note is the instructions say the plastic cover pops off from the back side. To me it's from the front side, where the back of the D-ring is would be the back side.
As you can see the foot print is a little smaller. Which should be good for underseat storage. It does however slightly expose the carpet edge in spots.
Just needing to cut a foam liner.
Pros
- Strong lid
- Bolted into metal
- Concealed
Cons
Ram lid removal
4x T-30 bolts
2x T-40
2x 10mm bolts
Installation
