The pulley is a press fit onto the shaft. Hemis have pretty much been using the same water pumps since they first came out, back when they had mechanical/viscous fans that attached to them. The threaded portion is where the fan clutch would mate to.
I know most water pump pulleys are press fit but most also have nuts.
So no nut is correct?
no nut november is in effect
Been working on them for 10 years and never seen one.
Am I crazy or am I missing the nut in the water pump?!? This is a shot from the bottom looking up. There are just threads there... Can someone with a hemi look and tell me if I lost the nut?!?!
Thanks!
Wow, that's a good find. I know I'd feel a little more confident if an "unneeded" nut was on there.
How will a nut improve on this?
