Hockeydad
Trying to find out what offset I will need without hitting upper a arm on the inside and yet not stick out past the fender. Thanks for any help looks like when you go to 24’s it gets limited.
I don’t know about 2WD, but there are some members running 24s... @Chavez98, for example.Trying to find out what offset I will need without hitting upper a arm on the inside and yet not stick out past the fender. Thanks for any help looks like when you go to 24’s it gets limited.
... maybe where you're from... But not if you want to go camping, hunting, or fishing in Colorado. Anyone want some stock 22's w/ 700mi n them?
I MAY consider $1,800 with local pickup. OR, $1,000 if you have some Longhorn or Laramie (off-road group tires on the Laramie wheels) wheels and tires with less than 1k miles on them.How much is exactly what I was going to ask.... I can pick up locally, unless you are in Rangely!
Actually the 24’s will only be 1” bigger diameter then what I have now. Going from 275/55/20 to 295/40/24. That’s nothing for 3.90 gears also it’s a 2wd drive it will never hop curbs or see a dirt roads but thanks for the input.Your going to regret putting 24” wheels on your truck. Wheels that large put such a burden on your suspension and drive line. Any zip you had off the line will be lost. Your brakes will have to work harder when stopping. I know your not going to listen to me because I sure as hell didn’t take anyone’s advice when I put large wheels on my truck. Yes it will look good and for the most part will ride ok on smooth streets. But any functionality / ruggedness as a truck is lost. Try hopping a curb, Or speeding over railroad tracks, Or driving on a gravel / dirt road. You don’t realize how stressful it is driving watching out for every pothole and uneven surface. Just so you don’t bend your wheels or get curb rash. Especially if it’s your daily driver. Been there done that.
That be me. I say do it but I’m bias.
Could you tell me what size tires you have and what is the offset of your wheels or even make and model of wheels and I could find out that info.That be me. I say do it but I’m bias.
Thanks
