Rims and tires on a 2019 Limited
jayram2875
What are some options either for changing just the tires or rim and tire
I have this same question. I'm pondering keeping the stock 22inch wheels, but going with a bigger tire without having to do any fairing cutting. The OEM wheels/tires are: 22x9 +19.05 offset rims and 285/45R22 32.1 diameter 11.2 width 5 inch sidewalls. If I go to https://tiresize.com/wheel-offset-calculator/ the only thing I can come up with is maybe a 285/55R22 which will get us 34.3 inch diameter total on the stock rims.
Keep me posted on your progress.
I went with Cooper Discoverer 275/65R20 on my stock 2019 - 1500 and no issues. Good looking tire, looks fairly aggressive, good winter traction for a daily driver (live in the midwest), but nothing for road noise. I also like the fact that Cooper has a 50k warranty on these tires. Sorry no good pics right now of the truck with the tires.
this is stock with 35
Thanks jay ram. This is exactly what I was looking for! You must be the first one on the net to do this type of vid. haha
I think this solidifies my decision to go with the 325/50R22 Nitto Terra's on the stock rims of my Limited. That puts the diameter at 34.8".
two questions...is 4x4 suspension any difference from a 2wd (height wise), if not, and you're saying its completely stock on your truck, then 35" should fit any '19 Ram?
Any pics? Considering this exact setup
It appears to be a air ride setup. Due to the fact it has the silver puck peeking out behind the top of the tire.
What are the exact size of the tires on the 19 limited at 35 with stock 22's? No rub at all levels without a lift assuming this has air suspension?
Would that require a calibration change on the speedometer?
