2019 Dodge Rebel Android Auto Issue
cvdw1964
So I just bought a 2029 Dodge Rebel n I have taken it into dealer n still have the same issues my Android Auto keeps going off n on anyone elses have this issue as it drives me crazy have tried new faster usb lines the dealership reset software they said n I even redid Android auto on my phone I don't have navigation on my u connect so it makes a huge issue! Thx ahead of time!
Neokane
Check your cable. This can cause problems
Kooch80
Washington
mine only seems to like the cable that came with my phone. tried an aftermarket cable (anker, who i think makes good products) and it didnt work. i plug mine into the usb-c port.
Neokane
I had to buy a new USB-C cable to get mine to work consistently.
SD Rebel
San Diego, CA
Same issue, it turns out my phone was the issue, it wasn't new and it wasn't securing the cable well enough at the base. Hit a bump, and the cable would move and disconnect.
A higher quality cable makes sure the connection is good, but the phone needs to have a good base connector as well.
cvdw1964
I was wondering if it's my phone that's why a new cable, gee just when I pay my phone off , guess I will be getting a new Goggle Pixel XL sigh
I have tried every cable u can think of so thinking it is my phone!
Thank you for the feed back n BTW Love my 2019 Rebel
SD Rebel
San Diego, CA
Absolutely! Just to be sure, when your phone is plugged into the cable, slightly move the cable at the base and see if it connects and disconnects, then you know that's it. The slightest movement on my cable would cause the phone to disconnect.
popcenator
Omaha, NE
That's my issue as well. Sometimes it disconnects it every bump, sometimes I make it most of my 25 minute drive to work. Sometimes it doesn't disconnect at all, but I know it's the port on my phone that's the problem. Though I didn't realize it at first and was a little disappointmented.
Sent from my Pixel 2 XL using Tapatalk
cvdw1964
Thanks I am looking into a new phone here just waiting for the 4th generation Pixel XL if I am going to get a new phone might as well get the latest one :0)
Have a great day!
2019REBEL
ON, Canada
How did you get a 2029 Rebel. :ROFLMAO: :p
gpbst3
I had the same problem with it connecting then disconnecting. Took it back to the dealership and the tech hooked his phone up and it worked fine. After that my phone started working. Cant really explain that one.
Djorgy
Here is a stupid idea to try! I had the same problem. Unrelated to the problem, I was at Verizon thinking of upgrading my phone and explained how I thought my USB c port was getting worn because of the connection problems in my truck. The gal at verizon took out a thin wire and cleaned my phone's USB c port out. It was full of pocket lint. Problem solved. No more connection problems with my android auto in my Bighorn!
TruckDriver
California
This right here EXCEPT - use a wooden toothpick or other non-metal item (so as not to short out any metal connections).. or compressed air first
Zinger
SE PA
A good cable is required for Android auto. I never had a problem with AA in the Ram, but recently I installed an aftermarket unit in my other car and AA would randomly disconnect. Eventually I tried a different cable and now it works flawlessly. I can't say why AA is so picky about cabling, but it is.
