Clock Inaccurate
TWRam
The clock always shows time being 1 hour ahead of actual. I can set it manually and it will stay for a short time, but it will revert to one hour ahead in short order. If I select "Sync with GPS" it instantly goes 1 hour ahead. At times my compass direction display shows blank. Another anomaly is that when I have my Iphone plugged in to the truck and I am using navigation on my phone, the navigation on my phone shows me as being somewhere 500+ miles away. Unplug my phone from the truck, and it goes back to normal. I believe my GPS has issues. Anyone have a fix for this?
Hi TWRam,
We are sorry to hear about your recent concern. Please private message us with your VIN and we can take a further look into this.
Laura
Ram Social Care Specialist
TW,
I am having similar issues. Yesterday my clock set itself to 2 hours early! There is some GPS issue. Please post if you find a fix for this.
Some have said disconnecting the negative terminal on the battery for 30 minutes then reconnecting may reset the GPS and clock. I haven't tried that yet.
Did you ever find a fix for this? Mine is doing the same thing. Clock an hour ahead (compass acquiring signal or 180 degrees off).
After the time change, my clock was 2 hours off. I set it manually and, for some reason, has been fine since. I'm skeptical that it fixed itself.
I finally disconnected the negative terminal on my battery for about 30 minutes. Reconnected and the clock and compass are both working as they should.
I disconnected the battery and everything seems to be resolved!
I tried that previously. No dice for me. Went right back to the wrong time once it got a GPS fix.
I’ve got the same issue with my gps and clock on ‘19 1500 Laramie w/ 10k miles. It was fine up until this morning. I don’t know what happened. The gps has done this before but never clock.
got the same issue with my 2021 Ram 1500...never had problem before but started lately
clock looses one hour ...need to set it manually but never the less goes back randomly
