Another ready lift level ?
Roddog2220
Arlington, Texas
Having some outer tire wear on all 4 tires, one suggestion the rep made was removing one of the spacers and I cannot remember if he said the upper above the strut or lower one, anyone do this?
From my understanding, you can’t get outer edge wear on a solid axle. How are you diagnosing the added wear?
diagnosed by discount tire showing me the thread on the outside of the back is wearing much faster than the inside
That’s really only possible if your rear axle is bent or your current rears used to be on the front. Someone please correct me if this isn’t the case on a solid axle.
there had never been a rotation, the only explaination i know is the truck sits high and it an aggressive tire used mainly in the city, im hoping more of a zero offset will help set the wheel out a little
