Roddog2220
Having some outer tire wear on all 4 tires, one suggestion the rep made was removing one of the spacers and I cannot remember if he said the upper above the strut or lower one, anyone do this?
From my understanding, you can’t get outer edge wear on a solid axle. How are you diagnosing the added wear?
That’s really only possible if your rear axle is bent or your current rears used to be on the front. Someone please correct me if this isn’t the case on a solid axle.
