Care to show how you have yours set up with this? Honestly, it's not hard to unscrew the catch can from the base to dump it out. I bought Mishimoto's valve and hosing for the bottom of the can, but not sure if I'm going to install it or not...
A clear can would be hugely helpful. That way you can tell at a glance if you need to service it or not...
You can easily reach hit and I just put a plastic cup underneath and open the valve. This way it never effects the seal where the can base attaches to the upper mounting section of the can and keeps the can air tight. For $13 it's a far better way to empty your can and great investment. No brainer!
I bought the Mishmito hose and valve and it's terrible and you don't need the hose with our set-up. Their valve is a cheap plastic and it cannot attach to the bottom of the can without installing the hose. Return it and buy the Amazon valve.
I bought the Amazon drain plug and installed it today. We'll see how it goes.
