2019 Rebel Issues
schmickram
Pocons, PA
Having some issues with my 2019 Rebel. I have around 2,500 miles on it, and it's already starting to make me regret not buying the new Super Duty. This is my 5th new Ram, and only the first one with any issues.
First: There is a "clunk" in the front end when hitting a notorious PA pothole. (Living in a private development, these are inevitable. And despite the ORP, one should assume a tight suspension.) Through other threads, I've learned to investigate the sway bar links for tightness. I will check on that this afternoon.
Second: I had a TPMS valve stem leaking. Light came on, I took it to a local shop to have it filled with N2, (55psi) as I do not have that in my home garage. The next day, wham! 44psi again. Had the shop break it down, and apparently the o-ring was pinched when it was assembled at the factory. $20 later, no more TMPS light!
Third: On the way to work this morning, my transmission started whining REAL bad. I will be calling the dealer at 9am to discuss this issue.
Forth: The 8.4 U-Connect sometimes doesn't turn on. If I shut the truck off and restart it, it will generally work.
Fifth: I've had to replace the exhaust gasket in the muffler flange, as it started to leak 3 days after I bought the truck.
Anyone else seeing issues similar to these? Or anything else I need to keep an eye on?
I have a rebel 12 (hk) with 1200 miles and 0 issues.
I have had mine for 2 1/2 months(2100km-1305 miles) and zero problems.
I feel like my 19 rebel is noisy over bumps and sometimes hops in the rear and makes noises. Trying to explain it is weird! Almost like a doink or clonk when the rear goes over bumps! Drives me bonkers! First truck I’ve ever owned, so not sure what to expect!
The liner in the front wheel wells is awfully close to the spring on my truck. Not sure if it's just how the Rebels are but that may explain the clunking over bumps. I'm thinking the liner is hitting something.
Sent from my Pixel 2 XL using Tapatalk
I have about 1,500 miles so far, no issues. Smooth and quiet, so much so it has surprised me. I came from a 2015 F150 2.7L Ecoboost which I thought was already very refined for a truck.
Of course my truck is still very young yet, so I got a ways to go.
Hi Jwrichardson,
We know you are reaching out to your fellow forum members, however, if you decided to have your dealer address your concern, and need additional assistance from our end, don't be afraid to reach out via private message!
Laura
Ram Social Care Specialist
My 19 rebel has 36k miles I had the clunking going over bumps took it to the dealer the solved it, other than that it’s only been to dealer for oil changes
