A few glitches
Beastram
Campbell river
A few glitchesWell my air suspension worked all of 10 minutes I got the raise it up and lower it and now it’s not doing nothing I hear the compressor pump going it’s staying over load,compressor cooling down. Back to the shop after one day and my puddle lights on my mirrors also don’t work. Anybody out there know if there’s a way to adjust the Tonnele cover so it clips on a little bit tighter there’s no information and I don’t see no adjustments other than putting maybe a little spacer on the clamp or another piece of rubber On the clamp or the body of the box
35 x 11.50 x 20 do fit the new Dodge Ram Laramie Even on enter and exit mode does not rub at all no offset on the Rims either
What's the offset on the stock 20s not sure if the we're the same as stock 18s?
What are the tire specs? 305/50? Looks great feel like I should have put wider tires on myself.
id try spacers on the clamp if it seems too loose.
I read someone else's thread about issues with the air suspension...the dealership is gonna have to fix that. Even some folks on YouTube have their trucks stuck on exit mode.
There must be a conversion app out to find out the tire size there is no off set
So air suspension got fixed a loose airline on the rear wheel was leaking .Let’s hope that’s the only thing I forgot to tighten
Three quality issues for the dealer to address:
1. Weather seal between left side front and rear doors is slightly deformed
2. Mismatch of style line between cab and box. Box sits low by 1/2 inch on right side.
3. Upper glove box lamp stays on. Forcing the door downward will switch the lamp off momentarily, but eventually comes back on.
No other problems or issues noted. Engine is super smooth and quiet; transmission is still learning but also much smoother now.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 001088 miles.
Regards,
Dusty
Hi Dusty1948,
We are sorry to learn of these concerns with your new truck. Have you brought these concerns to the attention of your dealer? Please send us a private message if you are in need of additional assistance.
Darlene
Ram Social Care Specialist
Hi Dusty1948,
Darlene
Darlene,
Yes, I have an appointment with the dealer on the 20th of this month.
Thank you for responding.
Best regards,
Dusty
