she came home from Ceramic Pro Gold package and I promptly threw on the peragon Tonneau. I C-Quartzed (UK) the Tonneau so its a bit shinier than normal powdercoat. The truck looks like she was dipped in glass.....amazing result.
Pulled off the mud flaps to get prepped for a deep clean, some polish and application of crystal serum light this weekend.
275/65 R20 Nitto terra grappler G2,
The only issue I have is that the ready lift 3.5 sst kit I have I may be selling as I love the look!
Gave her a bath
Drove her hard and scared some people in doing so.
Stay in your lane bro and it better not be the left. Road rage was tilted
Worked at a site I hadn't been to in a while.. got to see her in a new light. The level and tires are hands down my favorite mod so far.. The plastidipping and tint are tied for second
Gave my girl a spray off at the quarter wash. Rinse, soap spray, then rinse again. Took her home and wiped down with quick detailer to eliminate some of the water spots. Started a de badge process but didn’t finish unfortunately and she looks funny. It’ll be finished before the end of this long weekend tho. Also getting some tint done tomorrow. Can’t wait.
Ceramic tint Pano roof, back doors and rear window. Hoping this helps keep the heat down. I did the front windows and brow last month and didn't think about the factory tint not cutting out the heat. From what I have heard on here installing the ceramic over the factory really helps. Will be heading back to W Texas in a week and will see how it does.
Pics and tint % used?
I'm still playing around to get it just right (for Road use as a First Responder via the "In Motion" option).
I have the LED kit I got when I ordered my truck (all but the 3rd brake light for some reason).
So I had to go through the settings to tell it I had LED and not BULB (except for 3rd brake).
They were flashing too quickly or were barely visible (as BULBS take time to Light Up and Dim Down - LEDs are more-or-less ON/OFF in a sense).
http://www.zautotech.com/docs/Light Show Configuration Guide R2.pdf is where I was browsing and getting some ideas from.
Wish I would have had one for the Durango since I had the rear LED bar .. sorta like in this vid:
We're you able to map it to another button? I can't get it to work so kind of makes it useless as a first responder tool. Get toned...deal with radio and gear and then having to mess with dash menu to turn light on is worthless.
Looks great, was the C-Quartz easy to apply/get on even?
Thinking about doing mine but don't have a garage but that doesn't look necessary with the C-Quartz, also I wouldn't want to create a mess by getting it patchy or something.
I have not had time to play with it. Once My camera blue-screened and then it said my Adaptive Cruise Control stopped working, I could only unplug the TAZER then take the rig to work and reprogram it back to factory.
on a side note for what I did today:
I volunteered to work since it was a holiday weekend, and they SWORE I'd only be there until noon because it was a holiday weekend and local college game day .. well .. WRONG .. we were slammed!
I finally got out of there around 1430 (2:30pm) but I did walk out with:
1 - my new Limited Lower Grille (the lower open one compared to the solid Laramie one
2 - the 4 posts/knobs for the extended/not-extended bed divider (dealer paid for them)
going out to start pulling my grille to install the 2 piece LED lights, replace that lower grill and see if I can install my 18" grille LED kit, and install the not-so-extended bed extender parts.
I had peeled my tape off the windshield yesterday, and of course it rained all night, so the material under the carpet was wet (letting the dry out in the sun).
Got the ceramic coating process started today. Began with a hand wash, clay barred, and iron remover. Never knew how bad iron remover smelled.. got half the truck polished from the tailgate to the front doors.
Sadly this morning during the wash I found a really ugly deep scratch through paint on the front bumper. My guess is that someone backed into it. Probably take it to a shop to see what can be done.
I appreciate the rear power window even more now.
Ha, very handy and I've done that a lot. I came from a Tundra with the rear glass that goes all the way down which was even more useful. That's the one thing I miss about that truck.
Finished up for the day polishing. About 75% done. For the first time using a DA it took some getting used to. But her shine is impressive already and the ceramic coating hasn’t even been applied.
34886
