Panel/Body Alignment Issues
Dusty1948
Rochester, New York
The front of the bed is approximately 3/4 inch lower on the right (passenger) side and style lines don't line up with the rear of the cab. I'm planning on adding the factory chrome moldings from the Limited and this should be corrected before I apply them.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 000994 miles.
Regards,
Dusty
Can you order the chrome moldings from the dealer? Do you have a part number?
I've posted the part numbers on here about a month ago. Roughly $350. Give your dealer a VIN off a Limited and they can easily look it up.
Yes. They are a factory part for the Limited models. I do not havw a part number at this time.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 001088 miles.
Here you go.
My truck probably won't be here until October. I'm wonder if I can con the dealer into installing them?
After checking fifteen 2019s Crews on the lot, I noticed that my front bumper is seriously out of alignment. I'm beginning to suspect that the Quad Cabs had a lower priority on the assembly line.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 002804 miles.
Regards,
Dusty
also have a quad cab with serious grille and bumper alignments , have taken it to 2 dealerships , both said they have a lot like that and told customer service that the vehicle was " operating as designed" ( this battle isnt over yet )
My 2014 Outdoorsman was a little off but I could live with it. That one I would be hounding the dealers. That just not right.
