Do you have a specific battery pack that you would recommend? I have a hardwire kit; but I have been a little leery about using a battery pack.All of mine have been hardwired in and I’ve added the battery packs for peace of mind.
How do I connect my BlackVue camera? The only DC outlet is on top of the dash. Do the make any kind of adapter for the other kind of outlets (standard plug or usb) ? Thanks
Except if you want to record while at the dealer... They usually unplug to run diags etc.Power Magic EZ powers your BlackVue dashcam from your vehicle’s OBD (On-Board Diagnostic) port. No more searching for fuses at the fuse box.
just plug and play!
BlackVue Power Magic EZ OBD2 Adapter
Looking for an easy way to enable Parking Mode on your BlackVue dashcam? The Power Magic EZ connects to your OBD2 port for quick and painless installation!www.thedashcamstore.com
I thought this option would work best for the OP.Except if you want to record while at the dealer... They usually unplug to run diags etc.
This is how I have my V1 RD connected, which is no biggie, but on a dash cam, I would hardwire.
Cheers,
This is how I mounted and plugged my V1 RD up.Except if you want to record while at the dealer... They usually unplug to run diags etc.
Cheers,
