4” lift 35 nitto on 20” fuel
Boomer
Finally did the truck. Looks and drives great. 4” RC lift, 35 12.50 20 nitto ridge grapplers on 20x10 fuel wheels. -18 offset. Slightly aggressive. Looks and drives great!
Exactly what I want to do but with Toyo open country at3... but looks amazing!!!!
RC supplies the rear shocks. Ride is great. Took it to the beach today. Can’t recommend theses tires enough. Had them on my lifted 2014 ram
Truck looks awesome. I couldn’t agree more about the tire choice. I did Ridge Grapplers this time and love them. Amazed how quiet they are.
How’s the tires with a payload?
Only load I’ve put on them so far is towing my ski boat which is actually pretty heavy. Truck towed beautifully and tires tracked nicely and still no noise.
Where did you get the lift? I’ve been waiting for RC to release a 4” lift, only seeing the 3.5 and 6”.
Do you have a picture down the side to see how much the tires stick out past the flares?
Sport has the small fender flairs so it only out a little bit
yes. my shop made the blocks. they're closer to five inches I think. seems a little higher than my 2014.
They aren’t blocks. That’s a totally different thing.
Strut spacers in the front, coil spacers in the rear.
Lol. I know. This is my 4th lifted truck. Just trying to simplify. Most of the lift unchanged
Truck looks awesome! I have a similar setup on mine, but I went with 22 inch Fuels.
What exactly was done to make this a 4in lift? I’m tired of not fitting in the garage and I’m getting even more tired of waiting for someone to release a 4in kit!
It looks like the RC kit uses a top hat spacer and a pre-load spacer... I'd bet that if you left the pre-load spacer out, you would end up somewhere between 4-5" of front lift?
Just use a 4” spacer from the 4th gen trucks... but his issue is he has the 6” dirt logics. Only real option is to sell those and go with a shorter coilover shock (might exist because I think fabtech has a 4” kit now), or back to a strut and spacer.
Swap out to their 4” dirt logic and then sell your 6” ones to someone who wants to upgrade.
