4” lift 35 nitto on 20” fuel
It looks like the RC kit uses a top hat spacer and a pre-load spacer... I'd bet that if you left the pre-load spacer out, you would end up somewhere between 4-5" of front lift?
The issue there is that it will give you an extra inch of rake. Most people want the truck leveled with the lift.
It is a full suspension lift. Just a 6 inch top spacer in the front cut to 4.5 the rear is a spacer cut to 3 on top of spring. I looked into the 3.5 kit. Did not like the angles.
Has anyone else done this with the 6” kits? I’m thinking of going this route. I will utilize my mopar struts in the front with a 1.5” or 2” spacer.
How’s the tires with a payload?
Sorry for the slow response. :) Biggest payload I've put on them is 6 people in the cab and a 21' inboard wakeboarding boat loaded with gear. Tires did awesome. Still quiet under load. I now have 11,000 miles on them all conditions including snow, ice, mud, rain and dry. No complaints what-so-ever.
