Air Suspension - Smoother ride in Aero mode?
UltraMadMax
It seams that when I put the Air Suspension in Aero mode, the ride is smoother than when in normal height mode. Does anyone know if the loser the height the softer the suspension will be?
i'm not sure of that. the one thing i've noticed so far that when i put it in entry / exit mode once i start driving it will go back to aero mode but not normal. i have to use the switch to put it back to normal. now when i'm in normal and i get on the highway and it goes into the aero mode it will go back to normal when i get off the highway driving at a lesser speed. with my 13 ram if it was in entry / exit mode it would go back to normal on it's own. i'm going to check to see if this is working properly with my 19. but man what a nice smooth ride this truck gives you.
The pressure in the air-springs would be lower. That’s why they ride rougher in off road 2, the pressure is higher
I was experimenting with this the other day, aero mode is definitely the best ride.
