Truxedo Tonneau cover is bad a$$
nilidool
Just wanted to share a picture showing my new tonneau cover. I love that it is super low profile and not the pleather material.
jman307
Is that the low pro or low pro x15
Juli_hoop
looks good, do you know if they make it for a bed with ramboxes?
ZombieSlayer
Oregon
Is that gap in the front corners real or an illusion? If real .... I'll have to pass. I am looking for something to weatherize the bed during winter and don't really like the look of a topper on these trucks :(
Rick J
Northwest Washington
It looks like a gap but there is a piece of weatherstripping that's about 1/2 inch thick under there. Mine is water tight. As stated though, it might be the X15. Mine is the Lo Pro.
nilidool
There is a rubber spacer underneath there that makes the seal part stick up. I intend to eventually trim that seal so it fits around it and sits flat. Haven't confirmed if it is "weather tight" yet.
RamKen
Thanks, that’s the cover that I’m planning on getting. I’ve just been holding off to get a few more positive reviews from some of you guys. My one concern is that I have a drop in bed liner and I’ve read where some people have had to cut out around where the side rails meet the bulkhead and/or tailgate.
Repsol69
I have the same cover...X15...on those corners i put a small strip of velcro to hold the piece flat..seems to work fine... Love this cover and the matte finish..
19ramsport
That will likely be the case with any cover/rails. I had to do that on my last truck with a drop-in liner, the bulkhead was fine but all I had to do is notch a little piece out of the corner of the tailgate liner because the rails do sit tight against the tailgate.
I have this same X15 cover, so far so good. Just a few minor drips after a real heavy downpour.
BostonBLS
I am looking at getting this cover. What corner area sticks up that needs velcro? What exactly did you do?
theonlyMcG
Minneapolis, MN
I have the X15 for the RamBoxes. No issues with water, they give you a bunch of weatherstripping with it to seal up areas as well if needed. IMG_20191011_160104.jpg
Repsol69
The front corners behind the cab were just kinda buckled up so i put a small piece of velcro on each corner..bout a 2" strip per side...
