Is that the low pro or low pro x15Just wanted to share a picture showing my new tonneau cover. I love that it is super low profile and not the pleather material.
Is that the Pro x15 ?
It looks like a gap but there is a piece of weatherstripping that's about 1/2 inch thick under there. Mine is water tight. As stated though, it might be the X15. Mine is the Lo Pro.Is that gap in the front corners real or an illusion? If real .... I'll have to pass. I am looking for something to weatherize the bed during winter and don't really like the look of a topper on these trucks![]()
looks good, do you know if they make it for a bed with ramboxes?
I have the same cover...X15...on those corners i put a small strip of velcro to hold the piece flat..seems to work fine... Love this cover and the matte finish..There is a rubber spacer underneath there that makes the seal part stick up. I intend to eventually trim that seal so it fits around it and sits flat. Haven't confirmed if it is "weather tight" yet.
My one concern is that I have a drop in bed liner and I’ve read where some people have had to cut out around where the side rails meet the bulkhead and/or tailgate.
I have the same cover...X15...on those corners i put a small strip of velcro to hold the piece flat..seems to work fine... Love this cover and the matte finish..![]()
The front corners behind the cab were just kinda buckled up so i put a small piece of velcro on each corner..bout a 2" strip per side...I am looking at getting this cover. What corner area sticks up that needs velcro? What exactly did you do?
Can the ramboxes open all the way without pinching the X15?... About ready to pull the trigger on this cover before taking delivery of my Laramie Saturday.I have the X15 for the RamBoxes. No issues with water, they give you a bunch of weatherstripping with it to seal up areas as well if needed. View attachment 38366
