Dynamic Bi-LEDS don’t work
I have a Limited trim, 2019 May-built. I have no issues with my truck, except I think the dynamic bi-LEDs aren’t rotating. I enabled it from the settings and then rotate the steering wheel but it ain’t rotating. What am I doing wrong?
Check your manual you may have to have the turn signal on also
How are you testing? It’s not obvious to me when driving, but outside observers tell me that they can see the headlights moving.
I had my wife sit in the truck and turn the steering wheel all the way to one side while signalling while I stand in front of the truck watching it. Nothing. And this was at night time.
Again, try it while moving (e.g. in front of a glass-fronted strip mall at night).
May have to be going a certain MPH before they activate......
Probably have to be in Drive as well. Not sure it will work if the tranny is in Park. Just a thought.
They are active over 10mph or so (not sure what the actual spec is but I've never seen them move below that). Will not move when at a standstill..
