I'm not on here trying to antagonize those with a/c issues. But, just because some have them doesn't mean it's widespread, either. Sure, if something isn't working, I'd drop the truck off with the dealership for diagnosis and hopefully repair. Now, if something breaks and is repaired. I'm not going to hop on here and create a new thread. Stuff breaks. That's the reason for a factory warranty. This a/c system is better than my Corvette's.
Any manufacturer sees and tracks the warranty claims and if there's a trend they make an engineering change to fix it and dealerships are made aware of the fix with TSB's or if it is significant enough a recall.
A lot  of potential buyers hop on forums and think the worst about threads about complaints and I just try to add some overall perspective to some so that people might realize some issues aren't model-wide.
There are obviously some trucks out there with bad a/c. But, there are plenty that are just fine. I never use recirculate,  my side is auto 74° and my wife's side is at 73°. My mother in law rides in the back a lot as we're caregivers and she never complains about it being hot in the rear. Mine sits outside all the time, black in and out, with a panoramic roof. I don't care what temperatures are at the vents. They could be 55° for all I know. That's still way colder than I want. It can be sitting out in direct sunlight and the inside can be a 130°+ and the truck will cool to a comfortable temperature within 4-5 minutes. I do crack the windows for a bit to help get the smoking hot air out.
At this point,  I'm going to unwatch this and other a/c threads so I don't annoy those with a problem and leave it alone....
As I posted months ago, I did my own survey of  8 or more brand new Ram 1500s, on my preferred dealer's lot, all on the same day, within a space of maybe 90 minutes, and I can testify before the Supreme Court of the United States that 100% of the 2019 DT Ram 1500s had notably weak AC performance, and 100% of the 2018 DS "Classic" (Gen-4) ram 1500s had normal AC performance.
By weak AC performance I mean that holding my hand right in front of the center dash outlets, the time it took to begin to feel cool air on my hand after AC startup. Nothing to do with the size of the cabs and the total length of time it takes to cool a large cab - that's a totally different story. My testing had only to do with
the time the truck takes to start producing normally cold air. Every single 2019 DT Gen-5 Ram 1500 took far longer than any of the brand new 2018 models, and waaaaaay  longer than my wife's Mini, longer than our 15-year-old Prius. And in 100% of the cases, the 2019 DT Rams produced barely cool air, none of them produced air anywhere near as cold as our 15 YO  Prius.
I can't tell you the percentage of 2019 DT Ram 1500s that have the problem of significantly poor AC cooling performance, but I absolutely CAN tell you that the vast majority of all 2019 DT Ram 1500s I either test drove on the road, or started afresh & ran on the dealer lot, had really poor AC cooling performance.
In this day and age, when all other vehicles, including $25,000 Kia, Toyota and Honda sedans have absolutely STELLAR cooling performance, producing genuinely COLD air within the first ten seconds of AC startup, and when Ram bragged that the 2019 DT 1500 had something like 25% better cooling capacity than the Gen-4 DS-based 1500s, the fact that one single person here has to complain about their 2019 1500's poor cooling performance, IS A PROBLEM.
