Hi All,
I posted a few weeks back about which upper control arms to buy. I bought the 2018 ready lift model because I was told on here and by some on Amazon that they will work on my 2019 Ram because I didn’t want to buy the entire kit when I only needed the arms for $900 and we didn’t want pre load spacers that come with that kit. Anyway, we installed the arms with a 3.5” leveling kit and the first issue is when we went to get an alignment, the camber adjustments bolts are maxed out and the tech could only get it to .6+ and he should be able to get it to at least zero and preferably in the negative. Another issue is the ball joint doesn’t seem to get sucked into the knuckle all the way so now we’re wondering if we messed up by installing these arms? Thanks!
