Thought I'd contribute since so many have helped in their own ways.  I'm posting MY notes on "issues" noted by owners and their (attempted fixes).  I've tried to refer back to relevant posts to make sure I gleaned the correct info so post if I'm wrong.  Otherwise use with that in mind and you'll still have to search to find the posts/TSBs as I did not link the posts related to my notes....
QUESTIONS/ISSUES (FCA/dealer has to flag/list your VIN to be eligible for update fixes)NOISES/SMELLS
AUDIO/MEDIA
SUSPENSION/DRIVETRAIN
MISC
- Humming/drone noise upon deceleration/letting off gas> (MDS, update/unplug ANC, roll down windows, TSB 08-033-19)
 - Vibration/lugging/pulsating at low 1200-1900 RPMs at 20-30-40-50mph> (turn off/Tow-haul mode/update PCM-TCM-DTCM)
 - Cabin/whistle noise from unsealed gaps in vents/firewall/mirrors> (tape off gaps, find/seal holes in passenger box)
 - Rattling rear window> (fill in channel)
 - Squeaks/rattles/ticks in upper/lower console, headliner, doors, and speakers> (silicone, graphite spray, tie downs, foam/cloth tape)
 - Radiator shroud/assembly> (causes weed/skunk smell in cabin)
AUDIO/MEDIA
- NAV & Sirius subscription issues> (FCA vs Sirius problem, get All Access to match type of radio, get streaming option)
 - Intermittent audio/BT pairing/pops> (Note 8/9 issues?> The_Chemist/CJR/Matt_T/Jus Cruisin/RamJoe/*JAK have Note 9)
 - Android Auto won’t mirror/BT/charge/data transfer> (issues with cable/media hub/phone model/app-BT-USB enabled?)
 - UConnect won’t remember last source or GUI preferences> (flash updated?, use door/seat memory button or this actions list)
 - FM/Sirius presets lost> (update?, set user profile> put in P…hit the S button on door…followed by # of profile…hit lock on fob)
 - SSD & USB drives/media not recognized on UConnect> (firmware update, use NTFS)
 - Fluctuating volume on radio or green lines in cam vids> (autovolume, firmware update, or replace head unit?)
- Differential gear whine between 45-50mph> (oil low/bearings?)
 - Rear end clunks or car lurches forward> (like being bumped) when release brake or stopping (slip yoke binding or will “learn”)
 - Front end clunk> (check rubber bushings> reseat isolator bolts> tighten sway bar end, TSB replaces mounts/bolts)
 - Tranny shifts hard or won’t go to D> (replace?, TSB 1/9/2019)
 - Shift P to D> no move> touch gas> lurches forward or no move> (flash Park Assist or trans (replace?), R first then D, will “learn”
MISC
- Paint chipping along the lower/front edges of the vehicle> (PPF or running boards)
 - AC weak/imbalanced> (heater core leak into HVAC and/or faulty blend door> pinch or valves hack works)
 - Steering sticks/won’t recenter from left> (loose grnd, bad seal/gear in steering rack?)
 - Water leaks into interior from weld seams and window frames> (welds/unseated plugs/cracked window frame)
 - Windshield cracking on driver’s side at eye level on trucks with pano roof> (advises glass coverage)
