Glenn54
Has anyone replaced the OEM muffler or exhaust and seen an increase in MPG? I imagine there may be a slight increase in horsepower and you may get much better sound.
You might lose mpg enjoying the new sound of your exhaustHas anyone replaced the OEM muffler or exhaust and seen an increase in MPG? I imagine there may be a slight increase in horsepower and you may get much better sound.
I did!You
You lose torque with a cat back replacement?You'll lose more low end torque than you'll ever gain with high end HP. MPG will either not be affected, or go down. But, smiles per gallon goes up!
Me too...I did!![]()
really it sounds faster
Great points. If it was that easy to gain MPG or HP manufactures would do it. I always laugh at the intake and exhaust companies that make ridiculous claims.Most do, at least from what I've seen. There's a whole lot more than meets the eye when it comes to "freeing up" horsepower or torque on a modern engine. Reducing backpressure isn't the one-size-fits-all solution that it used to be, as the bottleneck in the systems aren't the same anymore with the extensive amount of resources available to manufacturers nowadays. Computers can do flow analysis on the entire intake, engine, and exhaust systems in mere seconds, where as 30-40 years ago it took a team of engineers hours and hours and hours. Replacing your muffler and expecting any sort of true gain is ASSUMING the mfg's left a HUGE bottleneck in a system so simple as the exhaust. It's the year 2019. We're 20-25 years MINIMUM beyond finding free horsepower in a new vehicle with anything short of re-engineering an entire system on any vehicle.
I'll be leaving the Ram stock. I'd like a little more exhaust noise sometimes but also love how quiet it is at cruise. Can't have your cake and eat it too so it will stay stock.
You
Thanks all. Riccnick, you've provided good information. I think I better forget changing exhaust in hopes of getting better MPG. I have a 95 F150 that I had dual exhausts with Flowmaster mufflers. It sounds great but is honestly a little too loud after awhile. I didn't really care about MPG with it because I just drive locally.
To add a little more insight to this.. the engineering recommendations based on their calculations/results do not always get followed through on in a lot of companies I have seen. It’s more like a half and half, a lot of variables come into play with manufacturing on this scale. Fiat might be big enough to handle making last minute changes and funding reasearch but they are also in the business of making money.Great points. If it was that easy to gain MPG or HP manufactures would do it. I always laugh at the intake and exhaust companies that make ridiculous claims.
I have heard this argument about losing torque before, but may I suggest watching this video of an engine on a dyno being tested with open headers, 2.5” exhaust, and a 3” system.With anything more "free flowing" from the cat's back, you'll lose more low end torque than you'll ever gain with high end HP. MPG will either not be affected, or go down. But, smiles per gallon goes up!
In their testing Torque is not lost with more flow.
Engine Masters
